Введение
If your Asus F555LA-AB31 will not connect to the network or if you experience intermittent connections, it may be time to replace your network card. Your network card connects your computer to a local area network (LAN) or the internet. If the network card has a faulty hardware component, the operating system might not show it as a connected device. It may also not reliably connect to networks or recognize networks in specific situations; such as when the laptop is hot or during extended use.
Before using this guide, verify the issue is not software related before replacing the network card. Asus provides a support guide to troubleshooting wireless issues in this link.
Electronics are sensitive to ESD. Here is a link for using an anti-static mat and wristband. The laptop must be unplugged before servicing to prevent electrical shock and hardware damage.
Выберете то, что вам нужно
Use the Phillips #0 screwdriver head to remove the ten 18mm Phillips #0 screws on the laptop's bottom.
Flip the laptop over and flip the screen up.
Pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
Use the Phillips #0 screwdriver to unscrew the one Phillips #0 screw that connects the CD drive to the motherboard.
Slowly slide out the CD drive, keeping it level, to remove it.
Carefully fold the device open.
Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
Fold the keyboard section of the laptop up towards the screen to fully expose the inside of the device.
Unscrew the four 4mm Phillips #0 screws holding down the hard drive.
Remove the seven Phillips #0 screws holding the motherboard down.
Lift the motherboard upwards, folding it towards the laptop chassis.
Unscrew the Phillips #0 screw holding down the network card, and slide it out.
