Введение
The access panel is a metal and plastic piece that encapsulates and protects the inner mechanical parts of a laptop. Be sure to have a compatible back panel for this laptop when replacing it.
Выберете то, что вам нужно
With the laptop facing down, rotate it so the battery pack is facing away from you.
Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
Insert a finger into one of the slots on the bottom panel.
Gently lift the upwards, and the back panel of the laptop will come off easily.
