Введение
Although uncommon, having to replace the speakers on the Asus G501JW-BHI7N12 could be useful should you want to upgrade speakers or if they are blown out from playing at too high of a volume. Either way, removing the speakers is one of the easiest repairs that can be done.
Выберете то, что вам нужно
Remove the four 7.0mm Philips #0 screws around the battery.
Unplug the connector highlighted in this picture by pulling it up and out of it's seating, then pull the battery away from the motherboard and remove the battery.
Using the metal spudger, insert the metal spudger between the speaker and pry up to remove it.
