Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide shows how to remove or replace the battery of an Asus G53JW-A1 computer. This may be necessary if the battery is worn out or damaged, and removing the battery is also sometimes necessary in order to replace other components.
  1. Start with the laptop upside-down. Turn the laptop so that the battery is facing you.
    • Start with the laptop upside-down.
    • Turn the laptop so that the battery is facing you.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Look to the right of the battery for a small black switch. Slide the right side switch to the right, away from the battery. When the switch is in the correct position, a red sticker will be visible underneath the switch.
    • Look to the right of the battery for a small black switch.
    • Slide the right side switch to the right, away from the battery.
    • When the switch is in the correct position, a red sticker will be visible underneath the switch.
    • On the left side of the battery is another black switch. Slide this to the left, away from the battery, and hold it in place there.
    • The left side switch does not have a red sticker underneath.
    • Slide the battery towards yourself.
Заключение
Tim Cedar
Участник с: 28.09.2018
934 Репутация
Автор 7 руководств
Команда
Oregon Institute of Technology, Team S1-G4, Lancaster Fall 2018 Участник Oregon Institute of Technology, Team S1-G4, Lancaster Fall 2018
OIT-LANCASTER-F18S1G4
3 членов
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 88
