Введение
Use this guide will help you access the fans in order to clean or replace them.
Tools needed: size 0 Phillips head screwdriver, opening tool, metal spudger
Выберете то, что вам нужно
Locate the 5 clips located at the top of the keyboard. Insert a metal spudger into the clip openings on the keyboard to remove the keyboard.
Before fully removing the keyboard, remove the back lighting cable and keyboard data strip.
In order to remove these cables, push forward the black retention clips and pull out the cables.
Using a PH0 screwdriver, remove the two, 4mm screws .
Using either your finger or a plastic opening tool, remove the back panel.
Using the PH0 screwdriver, remove the nine, 4mm screws on the bottom of the laptop.
Remove the four, 4mm screws located on both of the hinges using the PH0 screwdriver and flip open the device.
3 участников успешно повторили данное руководство.
Один комментарий
Some steps missing, regarding screws to remove: 1 screw that holds optical drive; once that is removed, 2 screws in the drive compartment; 2 screws in the battery compartment; 3 screws from the bottom of the motherboard.
