Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Use this guide to remove the keyboard on the Asus G73JH-RBBX05.
  1. Locate the 5 clips located at the top of the keyboard.  Insert a metal spudger into the clip openings on the keyboard to remove the keyboard. Locate the 5 clips located at the top of the keyboard.  Insert a metal spudger into the clip openings on the keyboard to remove the keyboard.
    • Locate the 5 clips located at the top of the keyboard. Insert a metal spudger into the clip openings on the keyboard to remove the keyboard.
  2. Before fully removing the keyboard, remove the back lighting cable and keyboard data strip. In order to remove these cables, push forward the black retention clips and pull out the cables. In order to remove these cables, push forward the black retention clips and pull out the cables.
    • Before fully removing the keyboard, remove the back lighting cable and keyboard data strip.
    • In order to remove these cables, push forward the black retention clips and pull out the cables.
Заключение
Еще один человек закончил это руководство.
Josh DeBest
Участник с: 23.01.2017
381 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 22-11, Maness Winter 2017 Участник Cal Poly, Team 22-11, Maness Winter 2017
CPSU-MANESS-W17S22G11
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 19
За всё время: 827
