Введение
Is your optical drive no longer reading discs? If so, here is the guide to fix the problem by simply removing the disc, buying a new one and installing it. All you need is the standard Phillips #0 screwdriver in order to remove the screws and plastic opening tools to remove covers.
Выберете то, что вам нужно
Slide the left slider to the left so that it locks in place.
Slide the right slider to the right while pushing the battery away from you. The battery should disconnect.
Turn the device off and remove any power cords. Dissassembling the device while it is under power may result in electric shock and potential damage to the device.
Rotate the device so the battery port is facing away.
Remove two 5.5 mm Phillips #0 screws on the back panel.
Insert the opener tool into the small groove at the edge of the panel.
Using opener tool, gently pry the back panel upward until it lifts free from the device.
Gently lift the panel off with your fingers.
Insert the plastic opening tool in the gap between the motherboard and the back panel, directly to the right of the RAM cards.
Gently push the optical drive outwards. This should require very little pressure.
Grab the loose optical drive with your fingers and pull it free.
Еще один человек закончил это руководство.
