Введение
If your hard drive is filling up or has become corrupted, use this guide to replace the Asus G73JW-XT1 Hard Drive.
Выберете то, что вам нужно
Slide the left slider to the left so that it locks in place.
Slide the right slider to the right while pushing the battery away from you. The battery should disconnect.
Remove the two 5.5 mm Phillips #0 screws from the back cover.
Gently lift and remove the back cover.
Remove the four 5.5 mm Phillips #0 screws.
Gently lift the hard drive starting on the far side.
