Введение
Display problems can be caused by a cracked screen. Cracks can appear as jagged lines or look like a spider's web. These cracks can affect just a portion of your display or disable your display completely. Follow this guide to replace your screen and restore your display.
Выберете то, что вам нужно
Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
Gently pry the front bezel away from the screen and back bezel with an opening tool.
Remove the six 6mm Phillips #00 screws across the top of the screen and the four 6mm Phillips #00 screws at the bottom of the screen.
With the screen free, tilt it gently forward to reveal the display data cable.
Unplug the display data cable by peeling off the clear sticker covering its connector, then pulling this connector out of its socket.
Remove the two side brackets from the sides of the screen by removing the six 3mm Phillips #00 screws attaching it. There are three screws on either side of the screen.
5 участников успешно повторили данное руководство.
