Asus G750JW-BBI7N05 Hard Drive Replacement
Выберете то, что вам нужно
  1. Asus G750JW-BBI7N05 Hard Drive Replacement, Battery: шаг 1, изображение 1 из 1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Hard Drive Replacement: шаг 2, изображение 1 из 1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Hard Drive Replacement: шаг 3, изображение 1 из 1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Hard Drive Replacement, Hard Drive: шаг 4, изображение 1 из 2 Asus G750JW-BBI7N05 Hard Drive Replacement, Hard Drive: шаг 4, изображение 2 из 2
    • Lift up the rubber stopper on the backplate to expose one Phillips #00 screw. Unscrew it until it becomes loose.
    • This screw is permanently connected to the backplate and cannot be removed. Unscrewing it only allows you to remove the lower case from the laptop.
    • The backpate is the plastic plate on the underside of the laptop that covers some of its easily accessible internal components.
  5. Asus G750JW-BBI7N05 Hard Drive Replacement: шаг 5, изображение 1 из 1
    • Use an opening tool to pry up the backplate along its edges, then remove it.
    • You may need to apply some force when prying up the backplate.
    • Keep in mind: During reassembly, replace the backplate starting from the bottom.
  6. Asus G750JW-BBI7N05 Hard Drive Replacement: шаг 6, изображение 1 из 2 Asus G750JW-BBI7N05 Hard Drive Replacement: шаг 6, изображение 2 из 2
    • On the left metal hard drive casing, unscrew and remove the indicated three 4mm Phillips #00 screws.
    • The right hard drive casing is for optional secondary hard drives.
  7. Asus G750JW-BBI7N05 Hard Drive Replacement: шаг 7, изображение 1 из 2 Asus G750JW-BBI7N05 Hard Drive Replacement: шаг 7, изображение 2 из 2
    • Use the black tab as leverage to slide the metal hard drive casing all the way to the left.
    • Still holding the black tab, pull the hard drive casing up to remove it from the laptop.
  8. Asus G750JW-BBI7N05 Hard Drive Replacement: шаг 8, изображение 1 из 1
    • Unscrew and remove the four 4mm Phillips #00 screws around the metal casing. Each side has two screws.
    • Slide the hard drive out of its metal casing.
Заключение
2 участников успешно повторили данное руководство.
Siyuan Yan
Участник с: 10/05/17
131 Репутация
1 руководство автора
Команда
Portland State University, Team S1-G1, Read Fall 2017 Участник Portland State University, Team S1-G1, Read Fall 2017
PSUN-READ-F17S1G1
2 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 19
За всё время: 2,269
