Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement
Выберете то, что вам нужно
  1. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Battery: шаг 1, изображение 1 из 1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: шаг 2, изображение 1 из 1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: шаг 3, изображение 1 из 1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: шаг 4, изображение 1 из 2 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: шаг 4, изображение 2 из 2
    • Remove the rubber stoppers in the top left and right corners to expose two 9mm Phillips #00 screws. Unscrew and remove them.
    • Unscrew and remove the three 4mm Phillips #00 screws inside the battery compartment.
  5. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: шаг 5, изображение 1 из 1
    • Carefully turn the laptop right-side up.
    • Using an opening tool, pry the outer edges of the hinge cover up and away from the laptop.
    • The hinge cover, located at the back of the laptop, is the long plastic plate that covers the hinges and speakers.
  6. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: шаг 6, изображение 1 из 3 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: шаг 6, изображение 2 из 3 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: шаг 6, изображение 3 из 3
    • Without disconnecting the speaker cable, set the hinge cover upside-down.
    • Hold the speaker cable by its white connector, then pull to unplug it from the motherboard.
    • You may need to apply some force, as these connectors can be difficult to unplug.
  7. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: шаг 7, изображение 1 из 1
    • The speaker is attached to the hinge cover by four 3.5mm Phillips #00 screws. Unscrew and remove them.
  8. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: шаг 8, изображение 1 из 1
    • Lift the speaker to remove it.
Заключение
3 участников успешно повторили данное руководство.
Stephanie Asling
Участник с: 10/05/17
424 Репутация
Автор 2 руководств
Команда
Portland State University, Team S1-G1, Read Fall 2017 Участник Portland State University, Team S1-G1, Read Fall 2017
PSUN-READ-F17S1G1
2 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 731
