Введение
This guide outlines how to replace the fan in the Asus GL551JW-AH71.
Выберете то, что вам нужно
Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
Flip the laptop on the right side while still holding the upper and lower assemblies close together.
Unplug the display connector from the motherboard.
Remove the upper assembly.
Unplug the fan connector cable from the motherboard with an iFixit opening tool.
With a Phillips #00 screwdriver, remove the three 5mm screws that hold the fan in place.
3 участников успешно повторили данное руководство.
