Введение
Charging port pieces inside of the laptop may get damaged and not allow it to charge. This guide will help you replace the charging port inside the ASUS K50IJ.
Выберете то, что вам нужно
Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
Press the tabs on the battery and lift them. The battery should come out easily.
Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
Remove the one .5 mm screw located in the top right corner of the battery compartment.
Remove the bottom panel by sliding it toward the hinges and lifting the back panel up.
Using the PH1 screwdriver, remove the 3 .75mm screws labeled as 1, 2, and 3 on the fan. NOTE these screws have the labels "1", "2", and "3" next to them.
Lift the fan up with your fingers.
Using the PH1 screwdriver remove the two .75 mm screws from the hinge side of the laptop.
Using the PH1 screwdriver, remove the four .75 mm screws from the copper heat sync. They will be labeled 1-4.
Pull the copper heat sync out of the laptop.
Using the PH1 screwdriver, remove four .75 mm screws from the driver, located in the bottom-right corner of the laptop.
Pull on the black tab on the driver to slide the driver back, and lift the driver out of the laptop.
Using the PH1 screwdriver, remove the five .5 mm screws from the SD card reader, located in the bottom-middle corner of the laptop.
Slide the SD card reader away and out.
Detach the white and black wires from the Wi-Fi card, located in the central area of the laptop.
Using the PH1mm screwdriver, remove one .5 mm screw from the disk drive, located inthe top-right corner of the laptop.
Using the PH1 screwdriver, remove the .75 mm screw from the plastic housing corner, located in the bottom-right corner of the laptop.
Unplug the wire and black cables on the motherboard, located in the upper-left corner of the laptop.
Using the PH1 screwdriver, unscrew the two .75 mm screws from the top-left corner of the motherboard.
Using the PH 1 screwdriver, remove the .75 cm screw from the top-middle section of the motherboard.
Using the PH1 screwdriver, remove the .75 mm screw from the top-middle corner of the motherboard.
Using the PH1 screwdriver, remove the three .75 mm screws from the bottom corner of the motherboard.
Slide the motherboard to the right and lift it up, but do not pull it completely out.
Use the metal spudger or opening tool across the top edge of the keyboard to pop it out.
Use the PH1 screwdriver to remove the .75 mm screws from the hinges. Each hinge has one screw.
Using the PH1 screwdriver, remove the .75 mm screw from the bottom-middle section was previously covering.
Using the PH 1 screwdriver, remove the .75 cm screw from the bottom-middle section where the keyboard was previously covering.
Flip the laptop back over. The charging port will be located in the top-right corner.
Еще один человек закончил это руководство.
Один комментарий
Cool really nice guide. If I could rate I would give it a 5 but I got one question. How tf do I put it back together now?
