Введение
If your entire keyboard is faulty, you can easily and quickly replace it yourself. The only tool needed to replace your keyboard is your blue prying tool.
Выберете то, что вам нужно
Turn off the device.
Disconnect the charging cable if applicable.
Push the two locking mechanisms away from the center of the device and slowly remove the battery.
Insert the blue prying tool into each of the five tabs at the top of your keyboard, moving from the outer edge inward. Use the blue prying tool to separate the keyboard from the palm rest.
Use your hand to gently pull the keyboard away from the laptop.
As the keyboard comes loose, gently lift the board up so the bottom is exposed
Use your fingers to gently disconnect the silver cable ribbon from the palm rest.
4 участников успешно повторили данное руководство.
