Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Запчасти
Детали не указаны.
  1. Start by removing the battery and 2 Ph0 screws indicated here, then slide the cover to access hard drive, RAM modules and Wi-Fi card.
    • Start by removing the battery and 2 Ph0 screws indicated here, then slide the cover to access hard drive, RAM modules and Wi-Fi card.
  2. Remove the RAM module(s) by displacing both metal tabs outwards.
    • Remove the RAM module(s) by displacing both metal tabs outwards.
  3. To extract the hard drive, remove 4 Ph00 screws indicated and pull the plastic tab to the left.
    • To extract the hard drive, remove 4 Ph00 screws indicated and pull the plastic tab to the left.
  4. Remove one Ph00 screw to pull the Wi-Fi card, then carefully disconnect both antenna cables, mind the black and white settings.
    • Remove one Ph00 screw to pull the Wi-Fi card, then carefully disconnect both antenna cables, mind the black and white settings.
  5. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  6. Remove every screw you are able to see from the back cover, and keep them safe. Remove every screw you are able to see from the back cover, and keep them safe.
    • Remove every screw you are able to see from the back cover, and keep them safe.
  7. You can safely remove all the screws from both sides of the battery, they won't let the display loose. You can safely remove all the screws from both sides of the battery, they won't let the display loose.
    • You can safely remove all the screws from both sides of the battery, they won't let the display loose.
  8. Take a small flat screwdriver and displace the 5 tabs holding the keyboard one by one.  Start on the right end and push the tabs in towards the screen as you lift the keyboard up. Lift the keyboard being careful with the flex cable. Release the keyboard ribbon from the motherboard by carefully sliding the black plastic part of the connector to the right.
    • Take a small flat screwdriver and displace the 5 tabs holding the keyboard one by one. Start on the right end and push the tabs in towards the screen as you lift the keyboard up.
    • Lift the keyboard being careful with the flex cable.
    • Release the keyboard ribbon from the motherboard by carefully sliding the black plastic part of the connector to the right.
  9. Remove every screw from this metal surface behind the keyboard. You'll find the mousepad connector hidden by an isolating tape. Lift up the black part of the connector to remove the ribbon.
    • Remove every screw from this metal surface behind the keyboard.
    • You'll find the mousepad connector hidden by an isolating tape. Lift up the black part of the connector to remove the ribbon.
    • You'll also find the power button flex cable hidden by a tape. Lifting the black part of the connector will also allow you to remove this cable.
  10. At this point, you'll be able to remove the DVD tray by sticking a clip to the opening hole. As shown in the photo, there are 3 ph00 screws you'll need to remove.
    • At this point, you'll be able to remove the DVD tray by sticking a clip to the opening hole.
    • As shown in the photo, there are 3 ph00 screws you'll need to remove.
    • If you've done everything right, the top cover will now be completely free.
  11. Remove the microphone and earphone flex ribbon by lifting the black piece of the connector upwards. To remove the display flex cable, there's a clear tape you'll have to clear away first (but do not disturb the yellow tape) then carefully displace the connector by pushing back against the two white lips of the cable to remove. Disconnect the speaker connector in the same way.
    • Remove the microphone and earphone flex ribbon by lifting the black piece of the connector upwards.
    • To remove the display flex cable, there's a clear tape you'll have to clear away first (but do not disturb the yellow tape) then carefully displace the connector by pushing back against the two white lips of the cable to remove.
    • Disconnect the speaker connector in the same way.
  12. To remove the motherboard, take away those 5 screws indicated in the photos. To remove the motherboard, take away those 5 screws indicated in the photos. To remove the motherboard, take away those 5 screws indicated in the photos.
    • To remove the motherboard, take away those 5 screws indicated in the photos.
  13. At this point, the motherboard should be free to release.
    • At this point, the motherboard should be free to release.
    • And that's it for me. The display assembly is not shown here, sorry.
Заключение
25 участников успешно повторили данное руководство.
Armando Rodriguez
Участник с: 17.08.2012
622 Репутация
1 руководство автора
Комментариев: 7
Awesome guide! my Asus K53E's power jack was damages and this guide made getting to the mother board to replace the part fairly east. In step 9 don't forget to check the entire back cover for screws before taking off the top cover, they arent all shown in the guide and there are a lot of them, if the case isnt coming away fairly easily you probably missed a screw so double check!
Greg Polinger - Ответить
Ok. I'm glad it worked for you. In my case, I fixed a noise in the headphone's output, caused by the flex cable connecting to the motherboard.
Armando Rodriguez -
hIGH marks for this guide. $4 power jack, $100 labor. Now I know why, but it was so worth it.
thanks.
da11a8 - Ответить
The power jack replacement I tried was useless because the solder was to difficult to remove and was nothing easy at all like tutorial videos on YouTube show! and I ended up breaking the Power jack area on the motherboard.
Shawn LH - Ответить
Shawn LH; I got the exact same problem! The power jack is soldered with alot of silver I guess, cause it needed a very high temp. 450C was just enough, and the extreme small space did not help much.. I replaced the jack but the DC jack area on the motherboard had suffered alot of heat, so it did not connect anymore. Now ASUS can't support me and they refuse to send me a new motherboard.. have anyone tried bying boards on ebay?
Great guide BTW! Very detailed information ^^
Thomas -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 17
За последние 30 дней: 50
За всё время: 50,074
