  1. remove battery by sliding the two release buttons to the right position. slide the battery away from the laptop slide the battery away from the laptop
    • remove battery by sliding the two release buttons to the right position.
    • slide the battery away from the laptop
  2. remove the 2 screws holding the plastic plate , underneath is the RAM/ WiFi and HDD the 2 screws are marked in red. afterwarts slide it away from the laptop
    • remove the 2 screws holding the plastic plate , underneath is the RAM/ WiFi and HDD
    • the 2 screws are marked in red. afterwarts slide it away from the laptop
    • keep track of all the screws and parts. make a map or a plan.
  3. click the ram module out of there sockets. push the metal clips away from the module. push the metal clips away from the module.
    • click the ram module out of there sockets.
    • push the metal clips away from the module.
  4. remove the black and white wire. remove the screw.
    • remove the black and white wire.
    • remove the screw.
  5. remove the 4 screws holding the metal frame , holding the hdd to it's place. slide the frame and hard disk away from the case. slide the frame and hard disk away from the case.
    • remove the 4 screws holding the metal frame , holding the hdd to it's place.
    • slide the frame and hard disk away from the case.
  6. click the keyboard loose . There are 5 clips to remove click the keyboard loose . There are 5 clips to remove
    • click the keyboard loose . There are 5 clips to remove
  7. be carefull with the flat cable from the keyboard. use a spudger to click the connector lid loose. i used the tip of a screwdriver.. but i know what i am doing.. if you are use to work on laptops you can use a screwdriver, if not use a plastic spudger.
    • be carefull with the flat cable from the keyboard.
    • use a spudger to click the connector lid loose.
    • i used the tip of a screwdriver.. but i know what i am doing.. if you are use to work on laptops you can use a screwdriver, if not use a plastic spudger.
  8. remove the screw hidden under the keyboard. slide the dvd bay out. slide the dvd bay out.
    • remove the screw hidden under the keyboard.
    • slide the dvd bay out.
  9. remove the flat thin cables from there sockets. use a spudger , click the lid upwards and slide the flat cable out. use a spudger , click the lid upwards and slide the flat cable out.
    • remove the flat thin cables from there sockets.
    • use a spudger , click the lid upwards and slide the flat cable out.
  10. remove the 6 screws ( m2x6) holding the metal plate to the case. remove the 6 screws ( m2x6) holding the metal plate to the case. remove the 6 screws ( m2x6) holding the metal plate to the case.
    • remove the 6 screws ( m2x6) holding the metal plate to the case.
  11. remove screws as shown in pictures. remove screws as shown in pictures. remove screws as shown in pictures.
    • remove screws as shown in pictures.
  12. remove screws as shown in pictures remove screws as shown in pictures remove screws as shown in pictures
  13. slide an isesamo opening tool between the two plates. you will here clicks slide an isesamo opening tool between the two plates. you will here clicks slide an isesamo opening tool between the two plates. you will here clicks
    • slide an isesamo opening tool between the two plates. you will here clicks
  14. remove upper plate , revealing the main PCB. remove upper plate , revealing the main PCB. remove upper plate , revealing the main PCB.
    • remove upper plate , revealing the main PCB.
  15. remove the flat cable of the USB module , use a spudger to lift up the lid of the connector. gently slide out the flat cable when removing the cable, be carefull they  used a lot of adhessive to paste the cable to the plastic case.
    • remove the flat cable of the USB module , use a spudger to lift up the lid of the connector.
    • gently slide out the flat cable
    • when removing the cable, be carefull they used a lot of adhessive to paste the cable to the plastic case.
  16. use the tip of a spudger or a tiny flathead screwdriver to push out the LCD cable from  connector. be very very very carefull , if you tear tis cable or damage it , you will have to buy a new one. first lift the cable metal connector upwards ( push it out) , very gently, then the other side untill you can remove the cable.
    • use the tip of a spudger or a tiny flathead screwdriver to push out the LCD cable from connector.
    • be very very very carefull , if you tear tis cable or damage it , you will have to buy a new one.
    • first lift the cable metal connector upwards ( push it out) , very gently, then the other side untill you can remove the cable.
  17. use IC extractor pliers to remove the cable away from is socket. use IC extractor pliers to remove the cable away from is socket.
    • use IC extractor pliers to remove the cable away from is socket.
  18. remove the 4 screws holding the main pcb .. remove the 4 screws holding the main pcb .. remove the 4 screws holding the main pcb ..
    • remove the 4 screws holding the main pcb ..
  19. remove screw holding the fan tot the laptop.
    • remove screw holding the fan tot the laptop.
  20. lift the main board or motherboard up on the right side and slide it out. lift the main board or motherboard up on the right side and slide it out. lift the main board or motherboard up on the right side and slide it out.
    • lift the main board or motherboard up on the right side and slide it out.
  21. release the fan from the main board by removing the connector with an IC extractor pliers. release the fan from the main board by removing the connector with an IC extractor pliers.
    • release the fan from the main board by removing the connector with an IC extractor pliers.
  22. loosen up the screws from the cooling pads on the CPU and GPU. You will have to tear the warranty sticker. it is a sticker in 3 parts. You will have to tear the warranty sticker. it is a sticker in 3 parts.
    • loosen up the screws from the cooling pads on the CPU and GPU.
    • You will have to tear the warranty sticker. it is a sticker in 3 parts.
  23. remove the fan and cooling pads. you will see the old thermal paste. you will see the old thermal paste.
    • remove the fan and cooling pads.
    • you will see the old thermal paste.
  24. clean the cooling pads with an very sharp knife. or spudger.. wear gloves, cause the thermal paste is very toxic.
    • clean the cooling pads with an very sharp knife. or spudger..
    • wear gloves, cause the thermal paste is very toxic.
    • also this is a good time to blow out the fan with compressed air.
  25. remove the old thermal paste from the processors , be very carefull. and use some artic silver liquid to clean them. and easely remove the thermal paste. you can remove the CPU by using a flathead screwdriver , the socket will move and you can pull the CPU out , maybe a good time to upgrade the CPU. you can remove the CPU by using a flathead screwdriver , the socket will move and you can pull the CPU out , maybe a good time to upgrade the CPU.
    • remove the old thermal paste from the processors , be very carefull. and use some artic silver liquid to clean them. and easely remove the thermal paste.
    • you can remove the CPU by using a flathead screwdriver , the socket will move and you can pull the CPU out , maybe a good time to upgrade the CPU.
  26. unfortunately i don't have a picture when i added some new thermal paste. But if you do: one drop on each processor is enough.
    • unfortunately i don't have a picture when i added some new thermal paste. But if you do: one drop on each processor is enough.
    • Check out the thermal paste guide for more information on how to apply thermal paste.
Заключение
5 участников успешно повторили данное руководство.
Kevin D
Участник с: 02.05.2014
6 619 Репутация
Автор 21 руководств
Комментариев: 3
You dont have to disassembly whole computer, just remove back cover, 4 screws from cpu, 2 screws from gpu and 2 screws from fan..
Aleksi Kinnunen - Ответить
Hi Aleksi,
Yes we know, but we took the hole laptop apart to show how to replace, renew other parts as well.
Kevin D - Ответить
Ciao, io ho fatto tutto perfettamente in modo identico alla spiegazione (anche perché non è complicato). può essere la cpu?
Irene Montanari - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 11
За последние 30 дней: 56
За всё время: 3,483
