Введение
If your Asus K55VD is having problems reading DVDs, not playing audio or videos properly, or DVD programs won't install properly then it may be experiencing a faulty optical disk drive which needs to be replaced.
Запчасти
Никакие детали не требуются.
    • Power off the device completely
    • Flip the device over to its back cover.
    • Use the switches to release the battery from its adapter.
  1. Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover. After removing the screws, remove the smaller cover.
    • Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
    • After removing the screws, remove the smaller cover.
  2. Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
    • Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
    The bottom left screw does not hold down the drive bay. Unsrew that screw in step 5.
    Daniel - Ответить
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Remove the hard drive from the slot. Remove the hard drive from its shell.
    • Remove the hard drive from the slot.
    • Remove the hard drive from its shell.
  5. Using the the Philips #0 Screwdriver remove highlighted screws.
    • Using the the Philips #0 Screwdriver remove highlighted screws.
  6. Lift plastic cover with tweezers.
    • Lift plastic cover with tweezers.
    • Remove screw.
  7. Lift keyboard panel with plastic pry tool to remove.
    • Lift keyboard panel with plastic pry tool to remove.
  8. Unhook all ribbons to remove keyboard panel completely. Unhook all ribbons to remove keyboard panel completely.
    • Unhook all ribbons to remove keyboard panel completely.
  9. Slide the DVD Player outward. Slide the DVD Player outward.
    • Slide the DVD Player outward.
Заключение
Hector Morales
Участник с: 21.09.2018
123 Репутация
1 Guide authored
Команда
University of North Texas, Team S1-G4, Riccardelli Fall 2018 Member of University of North Texas, Team S1-G4, Riccardelli Fall 2018
UNT-RICCARDELLI-F18S1G4
4 членов
Автор 5 руководств
Один комментарий
LOL if you want to get out drive, open dvd drive, turn laptop off, remove screw cover, unscrew, pull the drive out, done :D This is stupidly overcomplicated and unnecessary.
Luke Malatinsky - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 1
За 7 дней: 4
За 30 дней: 15
За всё время: 90
