Введение
This guide will detail how to remove and replace the battery on your ASUS M51E-B2 laptop. This is an easy procedure, as the battery was designed to be quickly removed by using a couple a latches. This guide can be useful if your laptop is frequently overheating, or will not hold a charge for very long.
Push and hold the left hand switch outward in the "unlocked" position using your fingers.
Еще один человек закончил это руководство.
