Введение
This guide shows you how to properly fix your laptop's swivel camera. This is an easy fix in order to get your camera to function properly. In order to accomplish this, you will need a dual-tipped metal spudger and a Phillips PH0 head screwdriver.
Выберете то, что вам нужно
Open the laptop.
Press and hold the power button until the laptop powers off.
Use the Phillips PH0 head screwdriver to remove the two 2.5 mm screws located on the left side of the camera.
Use the Phillips PH0 head screwdriver to remove the one 2.5 millimeter screw that goes through the left side of the camera.
Find the wiring harness on the right side of the camera.
Using your fingers, gently remove the wiring harness connected to the right side of the camera.
