Введение
The ribbon cable acts as a bundling unit to hold multiple wires together. Basically, instead of having a bunch of cords in random places, the ribbon holds them together as one, clean unit.
Выберете то, что вам нужно
Using the Jimmy tool, pry it into the seam of the device.
With the Jimmy tool, pry open the device through the seam.
Locate the black bundle cable connector attached to the battery.
Use the blue plastic opening tool to loosen the black bundle cable connector Loosen it in a back and forth motion towards the battery.
Use the plastic opening tool to loosen the battery by using the edges.
Lift the battery out of its port.
Using wide nosed tweezers, pinch the blue tab attached to the ribbon cable towards the top of the device that is inserted in the mother board.
In a lateral motion, pull the blue tab gently.
At the bottom of the device, use wide nosed tweezers to pinch the opposite blue tab of the ribbon cable.
Heat the iOpener in the microwave for one minute.
After heating, vertically place the iOpener on top of the ribbon cable. Let it sit for one minute.
Remove the iOpener.
Use the wide nosed tweezers to pinch the ribbon cable from the middle. Pull it up firmly to detach. Be careful not to rip it off.
