Asus MeMO Pad HD 7 Battery Replacement
Выберете то, что вам нужно
  1. Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: шаг 1, изображение 1 из 3 Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: шаг 1, изображение 2 из 3 Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: шаг 1, изображение 3 из 3
    • Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Pay attention so as not to lose them.
  2. Asus MeMO Pad HD 7 Battery Replacement: шаг 2, изображение 1 из 1
    • Unlock the ZIF connectors on the data cables.
    • Raise the white locking tabs by lifting their upper edge - furthest from the battery - they hinge across the width of the connector.
    • Remove the cable from its slot by gently pulling downward on the tabs.
    • Check that the touchscreen cables are fully seated when reassembling or touchscreen may have unresponsive areas.
  3. Asus MeMO Pad HD 7 Battery Replacement: шаг 3, изображение 1 из 1
    • Locate the battery connector by following the wires that come from the top right of the battery. To disconnect the battery just lift up gently on the wires. Use a spudger or blue plastic opening tool to gently lift the wires if it is hard to get a grip.
  4. Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: шаг 4, изображение 1 из 3 Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: шаг 4, изображение 2 из 3 Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: шаг 4, изображение 3 из 3
    • Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
    • The battery has a soft casing, be careful not to tear the battery casing as chemicals could leak out.
Заключение
15 человек успешно провели ремонт по этому руководству.
Julien Daigle
Участник с: 01/20/15
1 268 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 11-3, Blackwell Winter 2015 Участник USF Tampa, Team 11-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G3
4 членов
Автор 5 руководств
4 Комментарии к руководству
Make sure you REMOVE the micro SD card prior to opening it! Otherwise you risk damaging the micro SD card port.
I just opened my tablet to change the battery, didn't realize this, and sure enough, broke it :(
Hope this helps you avoid that mistake.
dpietros - Ответить Поделиться
How did you fix the sd card port?
yanisstavrou - Ответить Поделиться
It is VERY important that you do not bend the battery during removal!! Even more advisable is discharging the battery completely prior to replacement.... I accidentally bent the old battery while attempting to remove it and the battery heated up, bulged and then exploded!
Eric - Ответить Поделиться
where can i buy battery for asus memopad here in naga city, cam sur,philippines?
chattyubante - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 17
За последние 30 дней: 34
За всё время: 22,367
