Asus MeMo Pad 10 ME102A Motherboard Replacement
Выберете то, что вам нужно
  1. Asus MeMo Pad 10 ME102A Motherboard Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Insert the blue plastic opening tool into the seam between the back panel and the chassis.
    • When removing the back panel, remember to keep the device face down on a flat surface in order to prevent dropping the device or anything inside of the device.
  2. Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 2, изображение 1 из 1
    • Slide the plastic opener around the tablet. There will be spots of resistance. These should gently pop open as the tool slides through the seam.
  3. Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 3, изображение 1 из 1
    • After all of the clips have been opened, the back panel should be free to remove by hand
  4. Asus MeMo Pad 10 ME102A Motherboard Replacement, Speakers: шаг 4, изображение 1 из 1
    • The right-hand speaker is labeled ME102A-R and is located by the battery plug. This is the first speaker removed in this guide, however if the left-hand speaker is the only one you need to replace please skip down to the left-hand speaker section.
    • Unplug the speaker cable by gently pushing it parallel to the motherboard with the flat side of the blue plastic opening tool.
  5. Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 5, изображение 1 из 1
    • Unscrew the M2x4mm screw with the PH00 screwdriver attachment.
  6. Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 6, изображение 1 из 1
    • Lift the speaker up by the end opposing the steel latch and slide it out from under the steel latch. The speaker has now been removed.
  7. Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 7, изображение 1 из 2 Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 7, изображение 2 из 2
    • The left-hand speaker is designated by the lettering ME102A-L and is located by the silver and blue ribbon cable running across the top of the battery.
    • Remove the Ribbon cable labeled CN2 by gently prying up the white latch of the black and white plugs by using the small blue plastic opening tool.
    • Remove the Ribbon cable labeled CN1 by gently prying up the white latch of the black and white plugs by using the small blue plastic opening tool.
  8. Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 8, изображение 1 из 1
  9. Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 9, изображение 1 из 1
  10. Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 10, изображение 1 из 1
  11. Asus MeMo Pad 10 ME102A Motherboard Replacement, Motherboard: шаг 11, изображение 1 из 1
    • Use the blue plastic opening tool to lift open the black latch connecting the blue ribbon cable to the motherboard.
  12. Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 12, изображение 1 из 1
    • Using the blue plastic opening tool unplug the battery plug by gently pushing the plug out parallel to the motherboard.
  13. Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 13, изображение 1 из 2 Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 13, изображение 2 из 2
    • Using the PH00 screwdriver, remove the 4 black M2x4mm screws along the bottom of the motherboard.
  14. Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 14, изображение 1 из 1
    • Using the PH00 screwdriver, remove the 2 silver M2x2mm screws along the top of the motherboard.
  15. Asus MeMo Pad 10 ME102A Motherboard Replacement: шаг 15, изображение 1 из 1
    • Lift the motherboard gently from both sides.
Заключение
5 человек успешно провели ремонт по этому руководству.
Andreas Niederer
Участник с: 09/15/16
426 Репутация
Автор 2 руководств
Команду
USF Tampa, Team 11-3, Blackwell Fall 2016 Участник USF Tampa, Team 11-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G3
4 членов
Автор 10 руководств
Один комментарий
super flot hjælp tak tusinde gange
nielsnbc - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 12
За последние 30 дней: 15
За всё время: 1,936
