Введение
If you forgot your Password, Security PIN, Pattern Drill...
You can pass the security with a factory reset.We will show you how to do this.
!!! ATTENTION. This will erase all your personal data !!!
Видео обзор
First, try to pass the security with the Google account, registered on this tablet.
If you can't, then go to the next step.
Switch off the tablet and eject the memory card.
If you haven't memory card, you can use another, but it must be formatted at FAT32.
Google "asus memo pad how to reset to factory settings" and find the link to the official ASUS website.
Dounload "cleandata.zip".
Open "cleandata.zip" archive and copy contents to the ROOT directory on the microSD.
Put the memory card in the tablet and switch on it.
The tablet will go directly to the Android BSP Installation menu
In this menu use Volume Up/Down for movement and Power On to confirm.
Choose "clear user data"
After a while the tablet will ask you to remove the media (memory card).
The tablet tablet will restart and restore the system automatically.
Before installing the micro SD back, erase last copied files.
i tried same but not solve the issue
it's work 1000% for me
24 участников успешно повторили данное руководство.
19 Комментариев
the tablet don,t go to andriod bsp instalation menu
Try with another micro SD card.
ZFix -
Hey All, I was able to complete this task by placing the individual files from "cleandata.zip" onto the memory card. I tried placing the files from the zip folder onto the memory card, but that didn't work. Place only the individual files from the zip folder onto the memory card and re-boot and it will work...
Monk
make sure format it to FAT32
Power up the Tablet while PRESSING the (POWER)+(VOLUME UP)+(VOLUME DOWN) buttons all at the same time for several seconds..... the Android native boot loader will load allowing you to delete data and restore to factory defaults.....
I thought there was a simpler way!
how to install the ip address and the mac address?
beacause after i do it i cannot to the internet...
please help...
thanks
What if you don't have a micro SD card?
Thx dude, it work for me !
salutations from algeria :)
It work perfekt! Thanks
working 100% Thanks
thanks buddy its really work
boys trust on this file its realy work
keep it up and god bles you
I’ve found Asus Cleardata.zip and got booted into blue screen, selected clear user data, clearing process completes, removed install media (micro sd) as instructed, Tablet reboots... No fix! still stuck at boot logo. Tried a few times. Haven’t found further instruction as yet...
Thank you it really work
Thanks it worked…be blessed
