Введение
How to change the battery on Asus MemoPad ME172V.
This video is for Touch screen replacement, but at the beginning you can see how to open the back cover and how to separate the battery from the tablet.
Please SUBSCRIBE to my channel ツ
Video Overview
  1. With plastic tools remove the back cover. If you have a memory card inside - remove it first. If you have a memory card inside - remove it first.
    • With plastic tools remove the back cover.
    • If you have a memory card inside - remove it first.
  2. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Disconnect the battery connector. The battery is stuck to the LCD display frame with a double side adhesive tape. With plastic tools separate the battery.
    • Disconnect the battery connector.
    • The battery is stuck to the LCD display frame with a double side adhesive tape.
    • With plastic tools separate the battery.
  4. Li-Polymer Battery Pack, 3,75V, 4270mAh
Заключение
5 участников успешно повторили данное руководство.
ZFix
Участник с: 09.12.2013
162 527 Репутация
Автор 304 руководств
Команда
Master Techs Member of Master Techs
Community
280 членов
Автор 784 руководств
Комментариев: 2
Hello, i want know if it is the same operation for asus memo pad 7 me572c ?
bechir77bejaoui - Ответить
j'ai un probleme avec mon asus mémo pad 172v quand j'allume elle reste allumé le signe asus apparait avec le cercle de démarrage et elle reste comme ca elle ne s'ouvre pas est ce que probléme de batterie ,j'ai éssayé le flash mais meme problème
lord - Ответить
Просмотр статистики:
За 24 часа: 2
За 7 дней: 4
За 30 дней: 32
За всё время: 14,198
