Введение
This guide will help you replace the hard drive in case of hard drive failure or wanting to upgrade it. Be sure to follow this guide in a well lit room on a flat surface. Acquire the necessary tools before hand and have a cup or a magnetic plate to keep track of all the screws.
Запчасти
Никакие детали не требуются.
  1. Remove the ten 10mm Phillips #0 screws.
    • Remove the ten 10mm Phillips #0 screws.
  2. Use the iFixit opening tool to pry off the back cover of the laptop.
    • Use the iFixit opening tool to pry off the back cover of the laptop.
    • Remove the four screws from the hard drive bracket.
    • Remove the five 4 mm Phillips screws.
    • Pull on this black connector piece to remove it from the hard drive.
    • The second picture shows how things should look at this point.
    • Remove these two 4 mm Phillips screws holding the hard drive to the bracket. Repeat on the other side of the bracket.
    • Pull the HD from its housing.
Заключение
Houston Koontz
Участник с: 06.11.2018
295 Репутация
Автор 2 руководств
Команда
IUPUI, Team S1-G2, Hovde Fall 2018 Member of IUPUI, Team S1-G2, Hovde Fall 2018
IUPUI-HOVDE-F18S1G2
3 членов
Автор 3 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 11
За всё время: 64
