Введение
This guide will demonstrate how to remove the keyboard in your Asus Q325U.
Выберете то, что вам нужно
Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
Using a Phillips #000 screwdriver, remove the two 3mm screws on top of the orange battery connector.
Remove the first connection wire by pulling the small back loop with the Halberd Spudger.
Lift the small black tab of the orange connector with your fingers or a plastic opening tool.
Remove the orange connector by pulling with tweezers.
Lift the small black tab on the white plastic piece of the touch pad connector with a spudger.
Remove the touch pad connector by pulling with tweezers.
Lift the black tab on the long white plastic piece of the thick blue band.
Remove the thick blue band by pulling.
Remove the two Phillips #000 screws on the metal connector above the thick orange band.
Lift up the thick orange band.
Gently lift up the two smallest connectors using your fingers or a plastic opening tool.
Lift up the black hinge of the connector using a plastic opening tool.
Remove the connector using a tweezer.
Pull up the tap of the biggest connector using your fingers.
Lift the gold hinge using a plastic opening tool.
Lift the connector up with your fingers to remove.
Slightly open up the laptop. This will lift up the hinge at the corner and free the motherboard.
Remove the three 4 mm screws using a Phillips #00 screwdriver.
Remove the four 4.8 mm screws using a Phillips #000 screwdriver.
Slide out the blue chip board connected to the long orange piece by gently grabbing the tab and lifting.
Starting at the upper left corner, remove the black adhesive from the keyboard.
Remove eighty 1 mm screws located on the keyboard frame using a Phillips #000 screwdriver.
