Введение
If you are looking to upgrade your hard drive or replace a faulty one, this guide will give you the knowledge on how to do so.
Выберете то, что вам нужно
Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
Once the hard drive has been removed from the connector, use your thumb to get under and lift the hard drive out.
4 участников успешно повторили данное руководство.
