Asus Q501LA-BBI6T03 Wireless Card Replacement
Выберете то, что вам нужно
  1. Asus Q501LA-BBI6T03 Wireless Card Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Wireless Card Replacement: шаг 2, изображение 1 из 1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Wireless Card Replacement: шаг 3, изображение 1 из 2 Asus Q501LA-BBI6T03 Wireless Card Replacement: шаг 3, изображение 2 из 2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Wireless Card Replacement, Wireless Card: шаг 4, изображение 1 из 1
    • Pull up on the two metal tabs attached to the card .
    • Unscrew the single 2mm Phillips #0 screw in the top right hand corner.
  5. Asus Q501LA-BBI6T03 Wireless Card Replacement: шаг 5, изображение 1 из 1
    • Gently slide the card out of its connection ports.
    • Make sure to pull straight out of the connection ports to avoid bending of the card or port.
Заключение
Once finished, follow prerequisite guide in reverse order to finish your repair.
3 участников успешно повторили данное руководство.
Aodhan Arias
Участник с: 01/25/17
288 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 8-1, Banghart Winter 2017 Участник Cal Poly, Team 8-1, Banghart Winter 2017
CPSU-BANGHART-W17S8G1
3 членов
Автор 6 руководств
2 Комментариев
My Asus Q501L laptop cannot start the wifi card despite having updated the driver and restarting. Troubleshooting returns error Code 10. Did you experience or know how to resolve this problem?
Tony Ly - Ответить
Hey there Tony,
I would recommend first checking the status of the hardware device first. You can view a device's status from the device's Properties in Device Manager. It is possible that the driver is corrupted even though it is “updated” fully and could be causing the issue. If so, remove and reinstall the drivers for the device. It could also be that the WiFi card has a hardware issue. There isn’t really anything I know of that you can do besides just replacing it if that’s the case. If it’s new it might be under warrantee but who knows. Unfortunately Code 10 errors are pretty vague and don’t really give a lot of information. Hope this helps.
Aodhan Arias -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 928
