Введение
This guide teaches you how to replace the hard drive in an Asus Q502LA.
Выберете то, что вам нужно
Remove the ten rather long Philips screws from the bottom cover.
Use a spudger to pry the bottom cover off.
Remove the four screws securing the hard drive caddy.
Pull on the tab to remove the caddy from the laptop.
Unscrew the four screws holding the hard drive to the caddy. You're done!
2 участников успешно повторили данное руководство.
