Введение
The motherboard is where all of the communication happens in your laptop. Because the motherboard is such an integral part, this guide will show you how to replace it without damage.
Выберете то, что вам нужно
Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
Carefully insert a plastic opening tool under one corner of the back panel.
Slide the tool along the seam to gently pry the panel up and away from the device.
The battery is the large L-shaped block.
Remove the five 5.5 mm Phillips #1 screws securing it.
Disconnect the five wires attached to the motherboard by pulling gently. There are three thin wires in the upper left corner.
Remove the two 5 mm Phillips #1 screws attaching the stabilizer to the motherboard
Remove the four 5 mm Phillips #1 screws around the perimeter of the motherboard.
Remove the six 5 mm Phillips #1 screws securing the silver plates to the motherboard.
Open the laptop approximately 1/2" to loosen the hinge and release the motherboard.
3 участников успешно повторили данное руководство.
