Введение
You will need to replace the back panel of your Asus Q504UA-BHI5T13 laptop if it is badly cracked or you may just need to remove it to access the internal components.
Before beginning, power off your laptop and disconnect from the power cord.
Выберете то, что вам нужно
Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
3 участников успешно повторили данное руководство.
