Введение
The display of the Asus Q504UA-BHI5T13 device can be replaced when the laptop is no longer displaying a clear image. The repair is done by removing the display assembly. This guide will show the instructions on how to remove the back panel, hinges, and two connectors holding the Display Assembly.
Выберете то, что вам нужно
Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
Use the Phillips #0 screwdriver to remove the six 5.00 mm screws connected to the hinges of the display assembly.
2 участников успешно повторили данное руководство.
