Введение
This is a motherboard replacement guide for the Asus Q524U (Q524UQ) laptop. The motherboard is the main circuit board for the computer.
Выберете то, что вам нужно
Using your fingers, grip onto both sides of the wire harness and push it upwards.
Remove the five 3 mm screws holding the battery in place using a Phillips #0 screwdriver.
Remove the four 3 mm screws holding the fan in place using a Phillips #0 screwdriver.
Remove five 3 mm screws holding the heat sink in place using a Phillips #0 screwdriver.
After all screws and cables are unsecured, lift the fan assembly out of the laptop.
Remove the seven screws attached to the motherboard using a Phillips #0 screwdriver.
Using your finger flip the tab holding this light blue ribbon cable and move it out of the way.
Using your fingers, disconnect this wire harness by pushing it out from both sides.
With your fingers, pull this tab up to disconnect the wire from the motherboard.
With this tab out of the way you can now pull the motherboard out.
