Введение
Does your Asus Q525U laptop frequently make strange grinding or ticking sounds? If it does, here is a detailed guide to help fix the issues by replacing the hard drive.
Before beginning this repair, power off your laptop and disconnect from the power adapter.
Выберете то, что вам нужно
Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
The hard drive is located to the left of the battery and below the motherboard.
Remove the two 4 mm Phillips #1 screws which are holding the hard drive cover in place.
Lift the cover off, exposing the hard drive underneath [this laptop is missing its hard drive].
Еще один человек закончил это руководство.
