Asus Q534U Battery Replacement
Выберете то, что вам нужно
  1. Asus Q534U Battery Replacement, Back Case Removal: шаг 1, изображение 1 из 1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U Battery Replacement: шаг 2, изображение 1 из 2 Asus Q534U Battery Replacement: шаг 2, изображение 2 из 2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
    Step 2 I did not realize that the pictures to the right were enlarged for easier understanding of the step. Great walk through even a 66 year old man could understand and do it. Got the I Fix It tools which made opening the case and working with the tiny screws a breeze.
    Steven CARTER - Ответить
  3. Asus Q534U Battery Replacement: шаг 3, изображение 1 из 2 Asus Q534U Battery Replacement: шаг 3, изображение 2 из 2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
    Before doing anything here I would highly recommend disconnecting the buttery. I didn't do it myself at the beginning and when removing this ribbon cable I caused sparks going off the right connector.
    Alex Vasko - Ответить
    Great suggestion, Alex! This guide should now reflect a safer and more accurate procedure. Thanks for the heads-up.
    Richard -
    To clarify: you need to flip up the black plastic tab of the recepticle, not the cable. Then don't pull the blue tab up, you need to angle it up just a little bit, about 15 degrees, then slide the cable out.
    Gaspard van Ko - Ответить
  4. Asus Q534U Battery Replacement: шаг 4, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
Заключение
14 участников успешно повторили данное руководство.
mmedina
Участник с: 04/07/16
749 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 Участник UMass Dartmouth, Team S66-G6, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G6
3 членов
Автор 5 руководств
7 Комментариев
Is there a website link where I can get a replacement battery for ASUS Q534 UXK ? Model year 2016.
Lalith Sharavan - Ответить
Can this laptop be used without a battery?
Thomas Zakrzewski - Ответить
Thomas, yes. I found that out by mistake when I didn’t fully connect/lock the new cable and had to go back in and reconnect it. Worked as usual on AC power.
mmedina - thanks for the step by step. Worked like a champ for me.
Jeff Nurkiewicz - Ответить
Dear IFixIt,
Thank you for this straightforward approach to changing the battery on my ASUS Laptop Model Q534UX BHI7T19. The first attempt was 100% successful!! I can say that opening the laptop base was a little scary, but your step-by-step details removed enough fear of me screwing something up that I went for it!! Having the right tools on hand went a long way to getting fast results and great outcome. I highly advise viewers to purchase a tool set to remove the tiny screws and a plastic pry tool set (the one I purchased from Amazon was only $18 and included both) to make this task almost effortless. Without your guidance, I never would have attempted this project. Thanks again!!
Do you have similar guidance for changing out the hard drives on the above ASUS??
sheri scott - Ответить
Hi Sheri, thanks for your message! We’re so happy this guide was helpful. We have a hard drive guide as well. Check out the Asus Q534U device page, there are several other guides in addition to the battery guide. Thanks again!
Sarah Westberg -
Perfect instructions! Thank you for the guide and thank you ifixit for the made-in-Taiwan tools!
Jason van Biezen - Ответить
Would like to know how to replace the port for the power cord on the Asus Q524U.
Tammy Treefrog - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 17
За последние 30 дней: 89
За всё время: 11,477
