Введение
These steps will show you how to remove the hard drive from you computer.
You will need to do that if the hard drive is in a good condition but the computer is not, replace it to a new one to increase the speed and capacity, or the hard drive has experienced a hardware failure.
  1. Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 ,  two of them are 0.0793 JIS #0. Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 ,  two of them are 0.0793 JIS #0.
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Use the plastic opening tool to pry the back panel off the base of the laptop.
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Unscrew the four 0.0793 mm screws.
    • Unscrew the four 0.0793 mm screws.
  4. Using the PH0 and screwdriver from the 54 Bit Driver kit.
    • Using the PH0 and screwdriver from the 54 Bit Driver kit.
  5. After removing the four screws, gently push the hard drive downward as shown. After removing the four screws, gently push the hard drive downward as shown.
    • After removing the four screws, gently push the hard drive downward as shown.
  6. Lift the hard drive up.
    • Lift the hard drive up.
Заключение
2 участников успешно повторили данное руководство.
Wesam Badughaysh
Участник с: 09.04.2018
279 Репутация
1 Guide authored
Команда
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 47
За всё время: 1,245
