Введение
Use this guide to remove the battery in the Asus R510CA-OB01. In the event that your laptop doesn't charge, or doesn't work in general, you can use this guide to replace the battery in your device.
Locate the two switches that lock the battery.
Then, push the right switch outward to unlock it.
Еще один человек закончил это руководство.
