Введение
Use this guide to replace the display screen of your Asus R510CA-OB01 laptop. In the event that your screen is faulty or blurred or you'd like to update to a screen with better resolution, you can use this guide to replace the display screen in your device.
Выберете то, что вам нужно
Open the device.
Remove the black plastic squares on each side with a spudger.
Remove the two 5mm screws at each bottom corner of the display using a Phillips #0 screwdriver.
After the two screws are removed, use a plastic opening tool to remove the black cover around the screen.
Remove the four 5mm screws that attach the screen with a Philips #0 screwdriver.
Lift up the screen from the back of the laptop and then you will see a cable connected to the screen.
You can simply disconnect the cable and insert a new screen.
Еще один человек закончил это руководство.
