Введение
This replacement guide will aid users in upgrading their Hard Drive. Doing this is one way to make a device run faster and overall upgrade its performance.
This is not a cure all solution but it will aid in the speed at which the device can navigate through its programs.
Выберете то, что вам нужно
Using the Phillips size 0 head screwdriver, remove the 2 3.6 mm screws on the back plate located on the bottom left portion of the back of the laptop.
Lift up and remove the back plate that is located in the back, bottom left portion of the laptop.
Grab the plastic tab.
Gently pull towards the outer edge of the device.
Lift out to fully remove.
