Введение
This replacement guide will aid users in upgrading their Random Access Memory cards also known as RAM cards. Doing this is one way to make a device run faster and overall upgrade it's performance.
This is not a cure all solution but it will aid in the speed at which the device can navigate through its programmes.
Выберете то, что вам нужно
Flip the device over so that the bottom of the computer is easily accessible.
Using the Phillips size 0 head screwdriver, remove both 3.6mm. screws on the back plate located on the bottom left portion of the back of the laptop.
Gently pry apart the two white clips, that are holding in the RAM cards in, outwards.
