Введение
Experiencing audio troubles with your Asus ROG G55VW-DH71? Simply replace it by using this five step guide!
Great audio is a necessity for any computer user and your ROG G55VW-DH71 may be in need of an upgrade. Through this guide, your auditory needs and computer experience can be enhanced in only two minutes.
Выберете то, что вам нужно
Using the PH0 screw driver remove both 4.4 mm screws.
Using the PH0 screw driver remove the 6.4 mm screw.
Using the iFixit opening tool, gently pry open the plate covering the spine of the device.
Using the PH 00 screwdriver, remove the three 10.6 mm screws holding the sound bar down.
Один комментарий
Excellent tutorial. Thank you for your help.Excellent tutorial. Thank you for your help. I lost the back cover of my g55. I couldn't find a spare part here in Brazil.
