Введение
Replace a broken or messed up CD-Drive.
Before starting on this guide, unplug the laptop from its charger and turn the laptop off.
Выберете то, что вам нужно
Push the slider to the opposite side, while pulling out the battery.
Remove the battery from the device.
Remove the 4 mm screw on the cover using a Phillips #0 screwdriver.
Remove the cover for the hard drive by pushing down and sliding it towards yourself.
Flip the computer right side up and start to lift the keyboard. The keyboard/back panel should come off.
Gently pull the CD drive out of the side of the laptop and remove it from the device.
