Введение
If you need to install a new battery, access the battery with this guide. You may need to replace your battery if it doesn't charge or holds the same battery life as before. For this guide, you will need no tools. You will not need to do any difficult steps, but lifting up the latch with your finger to remove the battery .
Инструменты
No tools required.
Запчасти
  1. With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand. You can now fully remove the battery from the device. You can now fully remove the battery from the device.
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
    “With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.” Lots of wordiness.
    Coreyai - Ответить
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
Заключение
Jackson Reynolds
Участник с: 18.09.2018
328 Репутация
Автор 3 руководств
Команда
University of North Texas, Team S3-G7, Raign Fall 2018 Member of University of North Texas, Team S3-G7, Raign Fall 2018
UNT-RAIGN-F18S3G7
3 членов
Автор 4 руководств
Комментариев: 2
The note bullet should just be a bullet. Check grammar on the Red bullet.
Joseph McCoy - Ответить
“With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.” The sentence is too wordy you can remove “Where you can see the battery pop slightly up”.
Nicholas Ivey - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 3
За 30 дней: 7
За всё время: 74
