Выберете то, что вам нужно
Place the device upside-down. Unscrew the screw at the top of the cover and remove the cover by using a plastic opening tool.
Remove the screw that is located on the right edge of the removed cover. The screw is in a small opening.
Inside the opening that the screw was in, use a nylon spudger or any thin tool to push against the inside edge of the disc/optical drive.
With the disc/optical drive slightly popped out of the socket, pull the rest of it out by hand.
