Выберете то, что вам нужно
With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
Remove the large flathead screw holding the back cover in place.
Pull the cover off by prying it open starting from the top center and moving outwards.
Remove the eight short screws holding in the two metal covers near the bottom.
Remove the two metal covers.
Remove the battery to access the screws under it.
Remove these 16 screws with a regular Phillips head screw-driver.
These Phillips head screws will require a longer bit or an extension.
Flip the device back over.
Pull off the plastic cover behind the screen.
Remove the four Phillips head screws holding the screen in place.
With the screen removed, pry the piece that has the keyboard and the track pad on it.
