Введение
Use this guide to remove the speakers in an Asus ROG G751JL laptop.
Выберете то, что вам нужно
Use the point of a spudger to pry out four rubber plugs covering the screws on the bottom of the laptop.
Flip the laptop right-side up.
Use an opening pick to pry the left and right edges of the battery cover away from the laptop enough that you can grip the cover with your fingers.
Lift the battery cover straight up from the laptop.
Do not try to completely remove the cover yet, it is still tethered by a speaker cable.
Pull the speaker connectors straight away from each other to disconnect the speaker cable.
Remove the two 2.8mm screws on the left speaker housing using a Phillips screwdriver.
Remove the two 2.8mm screws on the right speaker housing using a Phillips screwdriver.
Using the nylon spudger, pry back the four clips holding the speaker connection cable in place.
Your are now clear to remove the speakers from the housing.
