Введение
Is your device running slow, or you simply need to replace some hardware? This guide covers the removal of the back panel on an Asus ROG G751JL-BSI7T28. Which is a crucial step when conducting further repairs.
Выберете то, что вам нужно
With the laptop closed, turn it upside-down so the bottom is facing up toward you.
Place a spudger into the notch, and pry the small triangular piece away from the laptop.
Using a Phillips #00 screwdriver, remove the single 3 mm screw.
Place a spudger beneath the back panel and pry it away from the laptop.
