Введение
This guide will demonstrate how to replace the Asus ROG G751JL-BSI7T28 display assembly on your Asus laptop computer.
This guide is helpful to those who wish to replace their display if it was broken or damaged. Symptoms of a broken display can range from a cracked or shattered display, patches of multicolored dots, one or more lines of discoloration, or a screen with rainbow colors.
The display is an LCD screen that has a size of 17.3”.
Detailed photos will accompany each step to provide a visual to assist in the disassembly of your laptop.
Warning: Ensure your device is powered down before starting this guide to prevent any electrical injuries or damage to your computer.
Выберете то, что вам нужно
With the laptop closed, turn it upside-down so the bottom is facing up toward you.
Place a spudger into the notch, and pry the small triangular piece away from the laptop.
Using a Phillips #00 screwdriver, remove the single 3 mm screw.
Place a spudger beneath the back panel and pry it away from the laptop.
Open the laptop and turn it so that the ASUS logo is facing you.
Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
Remove the 5mm Phillips #00 screws.
Lift up the silver hinge brackets on each side of the laptop.
Remove the 5mm Phillips #00 screws from the hinges.
Detach the ribbon cable and remove the display assembly from the laptop.
