Введение
This guide will demonstrate how to replace the fan in the Asus ROG G751JL-BSI7T28 laptop. The fan of a computer is critical to keeping the device cool, making its performance and longevity better. Symptoms of a faulty fan can include frequent overheating during heavy or normal computer use.
This guide is compatible with the following ASUS models: G751, G751J, G751JM, G751JT, G751JL, and G751JY.
Before beginning, make sure to power off your device before starting this guide to prevent any electrical injuries or damage to your computer.
Выберете то, что вам нужно
With the laptop closed, turn it upside-down so the bottom is facing up toward you.
Place a spudger into the notch, and pry the small triangular piece away from the laptop.
Using a Phillips #00 screwdriver, remove the single 3 mm screw.
Place a spudger beneath the back panel and pry it away from the laptop.
Open the laptop and turn it so that the ASUS logo is facing you.
Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
Remove the 5mm Phillips #00 screws.
Lift up the silver hinge brackets on each side of the laptop.
Remove the 5mm Phillips #00 screws from the hinges.
Detach the ribbon cable and remove the display assembly from the laptop.
Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
Remove the keyboard from the laptop.
Remove the 5mm Phillips #00 screw.
Pull up on the black tab connected to the fan. This will pull it away from the cooling fins, allowing it to be removed.
Remove the fan from the laptop.
