Введение
This guide will show you how to easily and successfully replace the fans within the ASUS ROG G751JL laptop. This is important for usability of the laptop.
Выберете то, что вам нужно
Lift the rubber cover found on the bottom of the laptop.
Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
Remove the screws holding the hard drives in place using a phillips #1 screwdriver.
Using the small flaps, remove the hard drives by hand.
Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
Use a metal spudger to carefully pry the top back panel off.
Disconnect the four-pin connector and remove the top back panel from the computer.
Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
Use a pair of tweezers to undo each of the four ribbon connectors.
The keyboard is now completely disconnected from the laptop and you can remove it.
Disconnect the four-pin connectors from each fan and remove them
The fans are now completely disconnected from the laptop and you can remove them
Еще один человек закончил это руководство.
